'76 Toyota Celica Mod list
(not all is installed yet)
Exterior:
PIAA SI Tech Silicone wiper blades
TRD badge for grille
aftermarket wheels
71-72 tail lights with center filler
Brakes:
Fuel:
Transmission:
short throw shifter
Interior:
Hurst T-handle (installed)
Sparco shift knob
Tenzo R seats
Grant steering wheel
Sunpro gauges
Toyhead auto polyurethane quarter window bushings
Motor/engine bay:
K&N air filter
Weber 32/36 carb
Hooker header
cat delete
Flowmaster muffler
MSD ignition components except wires & MSD box
Optima red top battery
Suspension:
185/60/14 Dunlop Direzza Z1 Star Spec
Tokico blue struts
new front end links
Atco sways?
What needs fixed:
-Paint
-Trunk lock missing
-Dash got hacked up to install a radio & some switches for aftermarket power windows
-Missing front lower valence
Plans beyond restoration:
18RG
we'll go from there...
smiley bumpers front and rear
front & rear side markers from a early model
TRD style spoiler
bullet fender mirrors
ST side sill stripe
script style Celica side badges
different wheels?
Tom's steering wheel
TRD racing buckets
Roll bar?
As for the other cars, I'll just post some pics and mods for now. If there's a section for it on here I'll put together some logs, if not I can always link you to one on an external site if you're interested in more info.
My NYG Neon sport coupe is the weekend driver / soon-to-be autocross car
'95 NYG Neon coupe mod list
(not all is installed)
exterior:
Carbon creations cf fenders
painted R/T wheels
APR splitter
Depo stealth headlights
Euro turns
brakes:
fuel:
24 lb/hr injectors
transmission:
Unorthodox Racing “stage 2” sprung hub clutch
interior
2nd gen center console
AEM Wideband
Optima red top in trunk
removed headliner for STICKERS!
Motor
PT 2.4
Magnecor wires
MSD coil pack
MPx UDP
Kirk Racing header
Autozone cobbled together intake (fancy)
Gates Racing timing belt
Mishimoto radiator
Mishimoto fans & shroud
FTB PDC mount
deleted engine to chassis plug
neongoodies.com semi-solid bobble strut
polyurethane motor mount inserts
Next is the Miata, daily driver and current autocrosser, hopefully soon to be replaced by the NYG for the latter duty.
'99 Mazda Miata mod list
Exterior:
de-pinstriped
'01 front end conversion
Sylvania Silverstar headlight bulbs
OEM hard top
17”x7” +42 Konig Holes w/ Yokohama Parada Spec 2 205/40ZR17
'01 tail lights
Garage 502 mirrors
Nielex front and rear tow hooks
Beatrush front license plate frame
slight hood tilt
Brakes:
Hawk HP+ pads
Goodridge stainless steel brake lines
DOT 4 fluid
Fuel:
Seafoamed
Transmission:
Royal Purple 75w120 & diff additive in rear diff
stainless steel braided clutch line
DOT 4 clutch fluid
Interior:
Mazdaspeed steering wheel (D-cut or limited edition)
NRG hub adapter
Maruha shift knob
Stuffed pedobear
Motor/engine bay:
ARC intake chamber
HKS SMF reloaded filter (red)
Magnecor KV85 race spark plug wires
NGK ZFR5F-11 spark plugs
Gates racing timing & accessory belts
Royal Purple 10w30 & filter
removed charcoal canister & other plastic bits
Garage Vary carbon fiber radiator cooling panel
Suspension:
Ohlins coil-over dampers (race valved)
Swift coil-over springs (12kg/mm front, 8kg/mm rear)
Carbing front & rear strut tower bars
Eibach sways
Good-win-racing heim jointed end links
RB front sway brace
RB front sway brackets
Next up is my FWD unlimited time attack build that's been a 4 year project so far. It's at least going to reach 5. I'm on the home stretch with it now though, it's more just been an issue with time to work on it. The car's in Ohio and I'm in CT... makes it a bit hard. Last time I got to go home was in January. This one comes with the bonus what's left list.
Black '95 Neon sedan mod list
(Not all is installed yet)
Exterior:
neongoodies.com tow hook
Seibon evo style cf hood
Vis cf trunk
Depo chrome projector headlights
shaved emblems
Erebuni F1 mirrors w/ LED turn signal
50% window tint front, 20% rear
Aerocatch black locking hood pins
SSC Thomas widebody front end (carbon fiber)
Brakes:
Fuel:
plastic tank swap, spoolboy mod
Aeromotive adjustable FPR
Boomba fuel rail
Mopar Stage 1 injectors
Edelbrock Quiet-flo 80 gph fuel pump
Transmission:
ebay polyurethane shifter bushings
Unorthodox Racing aluminum flywheel
Unorthodox Racing sprung hub 6 puck clutch
Quaife Automatic Torque Biasing helical LSD
B&M sts
Atx PT GT halfshafts
Interior:
Full gutting, including tar on floor. All that remains is dash frame, steering column, and wheel.
Sparco Milano 2 seats, will be switching out for something lighter
Varad shift knob to be switched out with something else
Razo cf look GT pedals
Autopower roll cage w/ window net
Motor:
SRT-4 motor w/ 4k mi
removed balance shafts
Unorthodox Racing oil cap
DCR upgraded oil pump
DCR big oil filter kit
DCR windage tray, crank scraper, baffle
DCR oil pickup
Energy Suspension urethane motor mount inserts
ARP head studs
Bobble strut relocation kit
Booger semi-solid bobble strut
Mishimoto aluminum radiator
Mishimoto intercooler
Hondata intake manifold gasket
HKS Hi power Ti muffler
Synapse BOV
Synapse wg
removed ps, a/c, washer fluid, charcoal canister, abs, air bags, heat
Boomba cam gears
Injen 3” downpipe
AEM pencil coils
AEM Twin-fire ignition module
AEM SRT-4 plug & play standalone EMS
MPX 3” O2 housing
Suspension:
'01 PT 5spd knuckles
BC Coil-overs w/ SRT lower threaded portion
Energy suspension bushings
Eibach anti-roll bars
neongoodies.com rear sway bar hardware
neongoodies.com offset rear trailing links
SPC Performance camber bolts
2nd gen hubs
What's left to buy/fab
Engine:
modify turbofold for Synapse external wastegate
fuel cell
-8AN fuel line
Braille battery 14115
Mishimoto fans (push)
HKS filter
custom exhaust, intake (flange for bov recirc), intercooler (flange for synapse BOV) piping
Moroso spiral flow muffler
AGP oil accumulator
AGP PCV breather
seam weld engine bay
Boomba throttle body
Aeromotive fuel filters
ARP exhaust manifold studs
Suspension:
AMR coilovers - in progress
SSR Professor SP1 17x9
BFGoodrich Gforce R1 275/40/17
plug steering rack
DCR rear camber/toe arms
tubular front control arms / k-member?
front control arm to front control arm brace
Brakes:
custom brake lines
SRT Wilwood BBK
SRT rear brakes
in-car proportioning system
Transmission:
scatter shield
Interior:
Flat black dash subframe
Racepak dash display
Axis Power Racing cf seat
carbon fiber dash
Exterior:
cf roof
Custom APR splitter
lexan windows
Safety:
under hood fire supression
5 pt harnesses
Driving suit
sheet aluminum wall between driver & trunk
kill switch
Aero ideas:
flat floor
rear diffuser
spoiler?
Last car is my 240sx. It really hasn't gotten much attention yet. I do plan to swap in a RB26 and make it a 180sx type-x look-a-like.
Took me forever to find an unbroken OEM rear valence set
That's it. If you took the time to read through, congrats, you have an insane car bug. Questions & pic requests are welcome. I kinda like taking pics if no one noticed...
