I'm back! I got my baby towed to my work.
Any chance I get, I work on her.
I don't know how the previous owner even got 50miles out of her.
The starter relay wires,were mixed up and one wire had a 20 fuse attached,that keeped on blowing.
Started her up,and she was misfireing and knocking,and I had the compression checked and all pistons are good!
I replaced the spark plugs,and now she runs better,but still knocking,so I got the valves adjusted,and replaced the valve cover gasket.
The gauges stop working took the dash apart. I turned the boost down,because I thought she was boosting 20psi,but the boost gauge was broken,but now it's fixed.
Then I put BG in the new oil,and BG in the gas tank to clean the injectors.
I made a bad mistake, I let the celica idle to clean the engine,and fuel system, and got caught up helping clients.
My baby overheated,and now she sounds even worse.
Tomorrow I'm off,so I will have more time to fix her up!
